Adobe har nu släppt Photoshop Lightroom 5 som varit i öppet beta-testande en tid.
Nu i den släppa versionen har över 400 buggar fixats och den innehåller nyheterna Advanced Healing Brush, Upright, Radial Filter, Smart Previews, Smart Previews samt förbättrat skapande av fotoböcker samt bildspel som blandar bild och video.
- Advanced Healing Brush: Remove distracting elements with a single brush stroke. Adjust the size of the brush and move it in precise paths. Unwanted objects and flaws—even those with irregular shapes like threads—just disappear.
Upright tool: Straighten tilted images with a single click. The new Upright tool analyzes images and detects skewed horizontal and vertical lines, even straightening shots where the horizon is hidden.
Radial Gradient tool: Emphasize important parts of your image with more flexibility and control. The Radial Gradient tool lets you create off-center vignette effects, or multiple vignetted areas within a single image.
Smart Previews: Easily work with images without bringing your entire catalog of original images with you. Just generate smaller stand-in files called Smart Previews. Make adjustments or metadata additions to the Smart Previews and apply your changes to the full-size originals later.
Improved photo book creation: Create beautiful photo books from your images. Lightroom includes a variety of easy-to-use book templates, and now you can edit them to create a customized look. Upload your book for printing with just a few clicks.
Video slideshows: Easily share your work in elegant video slideshows. Combine still images, video clips, and music in creative HD videos that can be viewed on almost any computer or device.
Personligen gillar jag verkligen den nya Advanced Healing Brush för att retuschera bort oönskade partier i en bild och att man nu genom Smart Previews inte behöver ha hårddiskarna med hela fotobiblioteket inkopplade för att jobba med bilder. Perfekt om man jobbar på en bärbar dator.
[youtube id=AeQgHYhbVd0]
En uppgradering från tidigare version till Adobe Photoshop Lightroom 5 kostar 665 kronor medan en helt ny licens kostar 1 205 kronor. Priserna är inklusive mons. Programmet ingår också i Creative Cloud.
Konkurrenten Aperture från Apple, som dessutom delar bibliotek med iPhoto, kostar 599 kronor i Mac App Store.
[source: http://blogs.adobe.com/photoshopdotcom/2013/06/lightroom-5-now-available.html “Photoshop.com Blog”]
Kommentarer
